Käyttöohjekirjan puuttuessa en löydä, mikä on mikäkin sulake.
Lähinnä kiinnostaa kaikki ajonestoon tavalla tai toisella liittyvät sulakkeet.
Onko jossain lista sulakkeista?
Nämä pätee C5-I RPO 8941-9365.
Konehuoneen sulakerasia:
F1 10A/15A High speed fan supply relay - mid speed cooling fan supply relay - vehicle speed sensor - diesel fuel heater - engine management control unit - reverse lamp switch - heater unit - air flowmeter
F2 15A Fuel gauge pump
F3 10A Selector lever position switch - anti-lock brake control unit - hydraulic suspension ECU - ESP ECU
F4 10A Relay 3 protection switch unit - automatic gearbox electrohydraulic block - engine coolant level switch - wash liquid level sensor - injection ECU - automatic transmission control unit
F5 10A Fuel additive ECU
F6 15A Front fog lamps
F7 20A Headlamp wash pump
F8 20A Timed supply cut relay
F9 15A/20A LH dipped beam
F10 15A RH dipped beam
F11 10A LH main beam
F12 10A RH main beam
F13 15A Low note horn - high note horn
F14 10A Front/rear screen wash pump
F15 30A Ignition coil - purge canister solenoid valve - cylinder injector 1 - cylinder injector 2 - cylinder injector 3 - cylinder injector 4 - cylinder injector 5 - cylinder injector 6 - carburettor or throttle housing heater resistor - front oxygen sensor - rear oxygen sensor - all or nothing solenoid valve (EGR) - engine management control unit - proportional oxygen sensor - variable timing electrovalve 1 - upstream rear oxygen sensor - downstream rear oxygen sensor - upstream front oxygen sensor - downstream front oxygen sensor - cylinder HT coil 1 - cylinder HT coil 2 - cylinder HT coil 3 - cylinder HT coil 4 - cylinder HT coil 5 - cylinder HT coil 6 - EGR + butterfly electrovalve - turbocharger pressure regulation solenoid valve - diesel injection pump - inlet air heater electrovalve
F16 30A Pulsair pump
F17 30A Windscreen wiper motor
F18 40A Heater panel (if separate)
MF1 50A Cooling fan thermal switch - cooling fan - high speed fan supply relay - low speed fan supply relay - cooling fan 2-speed resistance - cooling fan 2-speed 2 resistance
MF2 50A Anti-lock brake control unit - ESP ECU
MF3 Free
MF4 80A Built-in systems interface
MF5 80A Built-in systems interface
MF6 80A Cabin fusebox 12
MF7 30A Ignition switch
MF8 40A Central electronic block motor
BSI:llä olevat sulakkeet:
F1 10A Rear fog lamps - driver´s seat adjustment relay - passenger´s seat adjustment relay - sun roof one-touch motor
F2 15A Rear screen wiper motor
F3 Free
F4 15A Front RH door station - front LH door station
F5 15A Rear LH stoplamp - additional stop lamps
F6 Free
F7 20A Roof console + integrated functions - rear courtesy lamp - glove box lamp switch - heater panel (if separate) - front cigar lighter - forward 12 V socket
F8 Free
F9 30A Front RH door station - front LH door station - sun roof one-touch motor
F10 15A Fuel additive injector - caravan socket connector
F11 15A Engine management control unit - automatic transmission control unit - selector lever position switch - switching module below steering wheel (COM 2000)
F12 10A Automatic transmission programme selector - rear RH sidelamp - RH front sidelamp - number plate lamp - number plate right-hand lamp - ashtray lamp - front cigar lighter - radio
F13 Free
F14 30A Front LH door station - front RH door station - front LH door lock assembly - front RH door lock assembly - fuel filler flap lock motor
F15 30A Rear LH electric window unit + motor - rear RH electric window unit + motor - rear left-hand door lock assembly - rear right-hand door lock assembly
F16 5A Engine slave unit 34 fuse(s) - fuel additive ECU - switching module below steering wheel (COM 2000) - air bag and pre-tensioners control unit
F17 10A Rear RH stoplamp
F18 10A Cruise control safety switch (clutch) - cruise control safety switch (brake) - starter inhibitor relay - unused stoplamp switch - gear lever blocking actuator control relay - automatic gearbox control assembly - diagnostic connector - switching module below steering wheel (COM 2000)
F19 Free
F20 10A Radio - navigation ECU .
F21 Free
F22 10A LH front sidelamp - rear LH sidelamp
F23 15A Suspension electrohydraulic block
F24 15A Instrument panel - multifunction screen - colour display control unit - parking assistance ECU - heater panel (if separate)
F25 Free
F26 Free
2006: sain peräkontin tupaksytyttimen oikkariin ja sulake ns paloi. en vain löydä palanutta sulaketta?? ohjekirja vain antoi että F9 30A mutta ehjä oli. kävin läpi kaikki sulakkeet jalkatilassa ja ehjiä ovat ???
Kytkiksen mukaan olisi jalkatilan sulakerivin F39.
Lainaus käyttäjältä: KariM - tammikuu 15, 2015, 19:31:29
Kiitos "uskon valamisesta", en tiedä mikä numero se oli pimeässä, mutta kontin tupakansytyttimen sulake oli jalkatilassa, siellä ylärivillä jossa on normaalin kokoiset sulakkeet (30A).
