Kirjoittaja Aihe: C5 - mikä on mikäkin sulake?  (Luettu 4380 kertaa)
Poissa viitonen
« : Huhtikuu 17, 2011, 10:33:11 »
Käyttöohjekirjan puuttuessa en löydä, mikä on mikäkin sulake.
Lähinnä kiinnostaa kaikki ajonestoon tavalla tai toisella liittyvät sulakkeet.
Onko jossain lista sulakkeista?
Citroen C5 Hdi 136  Exclusive sedan -09
Poissa KariM
  • Peukkuja: 24
Vs: C5 - mikä on mikäkin sulake?
« Vastaus #1 : Huhtikuu 17, 2011, 11:53:32 »
Nämä pätee C5-I RPO 8941-9365.
Konehuoneen sulakerasia:
F1    10A/15A    High speed fan supply relay - mid speed cooling fan supply relay - vehicle speed sensor - diesel fuel heater - engine management control unit - reverse lamp switch - heater unit - air flowmeter
F2    15A       Fuel gauge pump
F3    10A    Selector lever position switch - anti-lock brake control unit - hydraulic suspension ECU - ESP ECU
F4    10A    Relay 3 protection switch unit - automatic gearbox electrohydraulic block - engine coolant level switch - wash liquid level sensor - injection ECU - automatic transmission control unit
F5    10A     Fuel additive ECU
F6    15A       Front fog lamps
F7    20A     Headlamp wash pump
F8    20A    Timed supply cut relay
F9    15A/20A       LH dipped beam
F10    15A    RH dipped beam
F11    10A    LH main beam
F12    10A    RH main beam
F13    15A    Low note horn - high note horn
F14    10A     Front/rear screen wash pump
F15    30A     Ignition coil - purge canister solenoid valve - cylinder injector 1 - cylinder injector 2 - cylinder injector 3 - cylinder injector 4 - cylinder injector 5 - cylinder injector 6 - carburettor or throttle housing heater resistor - front oxygen sensor - rear oxygen sensor - all or nothing solenoid valve (EGR) - engine management control unit - proportional oxygen sensor - variable timing electrovalve 1 - upstream rear oxygen sensor - downstream rear oxygen sensor - upstream front oxygen sensor - downstream front oxygen sensor - cylinder HT coil 1 - cylinder HT coil 2 - cylinder HT coil 3 - cylinder HT coil 4 - cylinder HT coil 5 - cylinder HT coil 6 - EGR + butterfly electrovalve - turbocharger pressure regulation solenoid valve - diesel injection pump - inlet air heater electrovalve
F16    30A    Pulsair pump
F17    30A    Windscreen wiper motor
F18    40A    Heater panel (if separate)
MF1    50A    Cooling fan thermal switch - cooling fan - high speed fan supply relay - low speed fan supply relay - cooling fan 2-speed resistance - cooling fan 2-speed 2 resistance
MF2    50A    Anti-lock brake control unit - ESP ECU
MF3       Free
MF4    80A    Built-in systems interface
MF5    80A    Built-in systems interface
MF6    80A    Cabin fusebox 12
MF7    30A    Ignition switch
MF8    40A    Central electronic block motor
BSI:llä olevat sulakkeet:
F1    10A   Rear fog lamps - driver´s seat adjustment relay - passenger´s seat adjustment relay - sun roof one-touch motor
F2    15A    Rear screen wiper motor
F3          Free
F4    15A     Front RH door station - front LH door station
F5    15A    Rear LH stoplamp - additional stop lamps
F6          Free
F7    20A    Roof console + integrated functions - rear courtesy lamp - glove box lamp switch - heater panel (if separate) - front cigar lighter - forward 12 V socket
F8          Free
F9    30A    Front RH door station - front LH door station - sun roof one-touch motor
F10    15A    Fuel additive injector - caravan socket connector
F11    15A    Engine management control unit - automatic transmission control unit - selector lever position switch - switching module below steering wheel (COM 2000)
F12    10A    Automatic transmission programme selector - rear RH sidelamp - RH front sidelamp - number plate lamp - number plate right-hand lamp - ashtray lamp - front cigar lighter - radio
F13          Free
F14    30A    Front LH door station - front RH door station - front LH door lock assembly - front RH door lock assembly - fuel filler flap lock motor
F15    30A    Rear LH electric window unit + motor - rear RH electric window unit + motor - rear left-hand door lock assembly - rear right-hand door lock assembly
F16    5A     Engine slave unit 34 fuse(s) - fuel additive ECU - switching module below steering wheel (COM 2000) - air bag and pre-tensioners control unit
F17    10A     Rear RH stoplamp
F18    10A    Cruise control safety switch (clutch) - cruise control safety switch (brake) - starter inhibitor relay - unused stoplamp switch - gear lever blocking actuator control relay - automatic gearbox control assembly - diagnostic connector - switching module below steering wheel (COM 2000)
F19          Free
F20    10A     Radio - navigation ECU .
F21          Free
F22    10A     LH front sidelamp - rear LH sidelamp
F23    15A     Suspension electrohydraulic block
F24    15A     Instrument panel - multifunction screen - colour display control unit - parking assistance ECU - heater panel (if separate)
F25          Free
F26       Free
Poissa DIY-Pena
  • amatööri
  • Peukkuja: 3
« Vastaus #2 : Tammikuu 15, 2015, 18:12:08 »
2006: sain peräkontin tupaksytyttimen oikkariin ja sulake ns paloi. en vain löydä palanutta sulaketta?? ohjekirja vain antoi että F9 30A mutta ehjä oli. kävin läpi kaikki sulakkeet jalkatilassa ja ehjiä ovat  ???
Poissa KariM
  • Peukkuja: 24
« Vastaus #3 : Tammikuu 15, 2015, 19:31:29 »
Kytkiksen mukaan olisi jalkatilan sulakerivin F39.
Poissa DIY-Pena
  • amatööri
  • Peukkuja: 3
« Vastaus #4 : Tammikuu 19, 2015, 20:39:47 »
Kiitos "uskon valamisesta", en tiedä mikä numero se oli pimeässä, mutta kontin tupakansytyttimen sulake oli jalkatilassa, siellä ylärivillä jossa on normaalin kokoiset sulakkeet (30A).
